3ds max slows down after a while
claudiuionescu
Hi there! I'm new to 3ds max and i have some problems...
I have a scene with 6 mils. polys / verts.
When I open 3ds(2015) with this scene everythings ok - more than 60 fps.
After ~30 minutes things goes crazy and the fps are getting low - less than 20 fps / and when I rotate the viewport ( perspective view - shaded ) the objects becomes wireframe for a few seconds.
Can anyone tell me what's the problem / a solution?
PC Specs
CPU -4930k
GPU - 780 Ti Dual Classified
32 GB RAM
SSD 256 GB
PS - excuse my language
could be anything , without the scene being posted such things are hard to catch, if the cause lies in the scene
But you might take a look at your task managers memory consumption for Max, i doubt that it hits your 32GB limit, but maybe it does because of some leak. And check wether your CPU is at 100% on some of it's cores when the slowdown happens
...20% of CPU uses...
Well - that means that one core might be fully clogged at 100% on your six core CPU. If this is Max using that CPU time with just the scene loaded without you doing anything this may cause a heat issue, as Scott mentioned ). For a test you might turn off progressive refinement of the viewport ( Max improves viewport rendering quality over time ). The setting is in Viewport Configuration->Display Performance->Improve quality progressively ). Check the CPU usage of Max and temperatures again after that...
Edited by spacefrog
It's not using only one core..
I tried with - Improve quality progressively and nothing happend. Thanks for answer anyway :D
