richardcousins Posted June 22, 2015 Share Posted June 22, 2015 Hi guys, I was wondering if any of you could help me. I'm looking to create a floor that is 100% see through but is reflective. Basically what I do is render POS designs and we want have our units on an invisible floor but with a reflection so you can see the reflection of the unit that is stood on it. We would also like the material to fade out from the centre so that you can see the line between the end of the reflective floor and the image we use as a backdrop. Any tips or help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Smile of Fury Posted June 22, 2015 Share Posted June 22, 2015 Maybe try this: Reflective Color = 255 - 255 - 255, Fresnel Reflections Off Use a VRAY DistanceTex in the Opacity slot. In the DistanceTex settings make the far color black, near color white and select your POS object as the VRayDistanceText Object. Play with the settings to get what you want. Link to comment Share on other sites More sharing options...
CliveG Posted June 23, 2015 Share Posted June 23, 2015 This might help too.... http://www.workshop.mintviz.com/tutorials/v-ray-hdri-studio-with-a-white-reflective-floor/ Link to comment Share on other sites More sharing options...
neil poppleton Posted June 23, 2015 Share Posted June 23, 2015 I would suggest render with various passes and comp together in photoshop to control what the result your after. Link to comment Share on other sites More sharing options...
jasonstewart Posted June 24, 2015 Share Posted June 24, 2015 This is the exact purpose of matte objects. As far as the reflection falling off just make the reflection map in the material a circular gradient light in the center dark toward the edges. Link to comment Share on other sites More sharing options...
richardcousins Posted June 24, 2015 Author Share Posted June 24, 2015 Thanks for all the answers guys. What I've tired to do is use vraymtlwrapper, set the alpha to -1.0 and in matte properties ticked matte surface and matte for refl/refr. I've also ticked shadows and affect alpha and this is the result I get. I can still see the plane and the edges of it. What am I doing wrong? Plus I don't know why it looks like a light is shining through the base of the unit.[ATTACH]53200[/ATTACH] Link to comment Share on other sites More sharing options...
richardcousins Posted June 24, 2015 Author Share Posted June 24, 2015 Link to comment Share on other sites More sharing options...
richardcousins Posted June 25, 2015 Author Share Posted June 25, 2015 Why cant I reply and why do all my posts have to be approved by an admin? Link to comment Share on other sites More sharing options...
richardcousins Posted June 29, 2015 Author Share Posted June 29, 2015 Hi guys. I think I have solved the problem now. Thanks for your help Link to comment Share on other sites More sharing options...
richardcousins Posted July 1, 2015 Author Share Posted July 1, 2015 Actually guys. I'm still having a problem. Here is a screenshot of my render. So its a simple 2 light set up. I have the floor as a vrymtl wrappermap to be matte and only show shadows. Now when I am in the vray frame buffer I am able to add a background image. Once I do this I then end up seeing the white where the plane is with the vrymtl wrapper on. Why is this? Link to comment Share on other sites More sharing options...
John Dollus Posted July 1, 2015 Share Posted July 1, 2015 in the vray properties of the plane, uncheck 'visible in reflection' Link to comment Share on other sites More sharing options...
richardcousins Posted July 2, 2015 Author Share Posted July 2, 2015 Thank you, You sir are a star Link to comment Share on other sites More sharing options...
