compositing in photoshop with alpha channel
Munz
I have been trying to composite a 3d rendering I did in max 7 with a photograph background in photoshop using an alpha channel. I can see the alpha channel in photoshop, but do not understand how to make it into a mask to effect the transparency of my image (I am assuming this is what I need to do). Does anyone know how to do this or know of a tutorial I could refer to.
thanks
munz
just select the alpha channel in channels floating window, and press the button "load channel as selection" (in the bottom part of this floating) this will select the white areas, go to the rgb channel (the first one) and you have the selection ready to cut or copy into the background image..........
