czoog Posted November 16, 2004 Share Posted November 16, 2004 New build posted to fixed the "slow down" issue http://revit.autodesk.com/download.asp From Steve Burri at Revit: Some save to central performance improvements: * Save to central back to same location after upgrade issue has been resolved Some file upgrade improvements were made including: * Sheet view corruptions were corrected * Grid heads flipping orientation upon project upgrade * Applying a view template from one view to another inadvertently copies the view's associated level as well Performance issues: * Related to memory were improved * Related to lengthy project browser were improved Display Issue: * Level lines do not show in section unless they are clipped by view boundary * Detail elements from family fail to show in project section Export / Import issues, including: * Improperly positioned section heads * Improperly positioned liked RVTs * Color fills export as white * ACIS import improvements Revision method, * “by sheet” not remaining persistent between sessions Filled region issues: * “white” regions no longer obscure objects * Regions cause Revit to exit on print hth, -Z Link to comment Share on other sites More sharing options...
NEVIANS Cedric Architect Posted November 16, 2004 Share Posted November 16, 2004 thanks for news.... go download now .... test it .. and wait the french version (certainly 7.1 .... patience is a vertue..) thanks a lot Link to comment Share on other sites More sharing options...
Richard McCarthy Posted November 17, 2004 Share Posted November 17, 2004 haha Chris you beat me to it well I been busy with work so I havn't check the forum, thread will be pin now. Everyone, go download the newest release now! it really does seem to fix up a lot of problems! Link to comment Share on other sites More sharing options...
