branskyj Posted June 30, 2015 Share Posted June 30, 2015 Hi all, After watching the "Take a Tour of the New 3ds Max" by Autodesk (at 29:47 minute) I found out that Max 2016 has a new feature where when opening a file with missing textures we get prompted with the familiar window but inside the window there is a new button. Now, I tried replicating the situation- created a cube, applied a wood texture (the texture was saved in a specific location), saved the scene and closed Max 2016. Then I deleted the wood texture from its location, re-opened the same scene and... not only was I not presented with the "missing textures" dialog window but also my cube had the wood texture applied to it. I sampled the cube and found out that the texture had a new location now- it was on a different drive. So, I guess prior opening the file Max 2016 has searched my hard drives looking for a file with the same name as the deleted one and has re-mapped the location. I admit- that is very handy but can also be a problem- what if the files only have the same names but are something completely different? Does anybody have any idea if I can modify that behavior of Max? Has anybody even stumbled upon that yet? Thanks. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted June 30, 2015 Share Posted June 30, 2015 If you go to customize - customization - configure user paths - external files you can add folders that max will look through for external content. As long as a texture in one of those folders has the same name as the one you made dissappear, max should find the other one. So this does not sound like something new with 2016. Link to comment Share on other sites More sharing options...
branskyj Posted June 30, 2015 Author Share Posted June 30, 2015 Thanks Nicolai, I will check this out. I guess my Max 2015 and 2016 are setup differently then because reproducing the same in Max 2015 led to the "missing textures" dialog window. Regarding the new in Max 2016- like I said it should be an additional button in the initial dialog window. Cheers mate. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted June 30, 2015 Share Posted June 30, 2015 Hmm, now that you mention it i am no longer sure. I did a test in 2015 and got the same as you, the missing textures dialog window. Not really sure whats going on. I may just have recalled incorrectly, too many long hours before summer vacation! Hope you figure it out! Link to comment Share on other sites More sharing options...
branskyj Posted June 30, 2015 Author Share Posted June 30, 2015 No, no- what you said make sense, though I am not sure if that is indeed the case. I just got given a new project and can't test it but will do so from home and post again. Thanks Nicolai. Link to comment Share on other sites More sharing options...
