branskyj Posted July 2, 2015 Share Posted July 2, 2015 Hi all, I am looking for a way to assign the forward/back mouse buttons (not the main two but the smaller side buttons) as hotkeys in Max. Does anybody know if there is a way to do that? I tried to do so through Customize/Customize User Interface but that of course did not work Thanks everybody. Link to comment Share on other sites More sharing options...
numerobis Posted July 2, 2015 Share Posted July 2, 2015 Coming from ACAD i used to have F3 and F8 on my mouse. Now i use them in combination with Shift/Alt/Ctrl to create shortcuts in other apps like Sketchup. This works in Max as well. (of course you can assign any key to the mouse buttons if your mouse software supports key assignment - you don't have to use the F-keys.) Link to comment Share on other sites More sharing options...
branskyj Posted July 2, 2015 Author Share Posted July 2, 2015 (edited) Hey numerobis, How exactly did you manage to assign the forward/back mouse buttons as hotkeys in Max? Because I tried again now through the Customize/Customize User Interface but Max won't register them in the Hotkey dialog box. Normally when you punch in a key it would be displayed in that box but nothing appears there when I press the mouse buttons. I also tried in combination with Shift/Alt/Ctrl but didn't work either. Did you use a third party software? Thanks a lot, mate. Edited July 2, 2015 by branskyj Link to comment Share on other sites More sharing options...
Dejan Sparovec Posted July 2, 2015 Share Posted July 2, 2015 You should be able to do this by using your mouse's driver/software to change what those buttons do. For example Logitech has SetPoint software where you can assign any keystroke or other functions to those buttons. Link to comment Share on other sites More sharing options...
branskyj Posted July 2, 2015 Author Share Posted July 2, 2015 Aha, I see. I will see what Steelseries have on their web-site, Dejan. Just out of curiosity- when you do that through SetPoint, what do you see that is related with 3DS Max? I don't suppose you see things in SetPoint such as "...assign forward button to Loop/Ring edges". Cheers to you too, mate. Link to comment Share on other sites More sharing options...
Dejan Sparovec Posted July 2, 2015 Share Posted July 2, 2015 Max sees it as whatever keystroke you assigned to that button, all of Windows sees it the same. You basically say: I want the back button to act as the space bar or left Ctrl or F4 or whatever... I can't set the back and forward buttons to do anything in max, either, but it's possible to set up different profiles for the mouse, so you can switch between them and not have to reassign the buttons back. Link to comment Share on other sites More sharing options...
branskyj Posted July 2, 2015 Author Share Posted July 2, 2015 Gotcha. Thanks a lot for the help and have a nice weekend Link to comment Share on other sites More sharing options...
numerobis Posted July 2, 2015 Share Posted July 2, 2015 Did you use a third party software? No. The original Logitech Gaming Software. Link to comment Share on other sites More sharing options...
branskyj Posted July 3, 2015 Author Share Posted July 3, 2015 No. The original Logitech Gaming Software. Thanks, mate. Link to comment Share on other sites More sharing options...
mi75 Posted July 7, 2015 Share Posted July 7, 2015 I use "X-Mouse Button Control". Its free and allows you to setup application profiles etc.... Link to comment Share on other sites More sharing options...
branskyj Posted July 7, 2015 Author Share Posted July 7, 2015 I use "X-Mouse Button Control". Its free and allows you to setup application profiles etc.... Thanks, Martin. I will try that one tonight. I gave the Steelseries Engine 2 a try the other day but it doesn't allow assigning things to the mouse buttons. Link to comment Share on other sites More sharing options...
