rajeshpr1 Posted July 15, 2015 Share Posted July 15, 2015 Hi Everybody, Iam very new in Vray rendering. here my issue is, [image attached] some grey spots in the ceiling. please advice me how to get good result in the view [im bad in english. so not writing more] Link to comment Share on other sites More sharing options...
Chris MacDonald Posted July 15, 2015 Share Posted July 15, 2015 What software are you using? What render engine are you using? What is your lighting setup like? What is your material setup like? What are your render settings? Do you have any render elements that can narrow down the source of the noise? Link to comment Share on other sites More sharing options...
rajeshpr1 Posted July 15, 2015 Author Share Posted July 15, 2015 Sorry, i forgot to mentioned those. 3D max 2012 with Vray 2.3. i used vray 4 vray plane light inside the room. and one direct light from out side. material is defaultl vray material. no rendenr elements added. GI engine irradiance map and Light cache.[sub div is 1000] and give one light from below which include ceiling. camera is standard. thank you. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted July 15, 2015 Share Posted July 15, 2015 Are you using large V-Ray plane lights in your ceiling? That dirty noise seems to be low samples in your lights. maybe it is default 8 now, increase to 32 or so, it should clean up. Try to avoid of using "Fake" large Plane lights, start putting light where the light fixtures are, then just then if it is need it, place some extra hidden light. but for 99% of the time, if you follow architectural design, those light should be enough. Fco. Link to comment Share on other sites More sharing options...
rajeshpr1 Posted July 16, 2015 Author Share Posted July 16, 2015 Sir, thank you so much..... it is clear now.. one more doubt. Is it good to give photo metric light with web instead of v ray plane light.? which is preferable for similar scenes.? thank you. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted July 16, 2015 Share Posted July 16, 2015 glade to help. Using Photometrics light is not better, is not worse, some people may say they prefer because they are "Physically correct" or they get "real' Lighting conditions instead of using a random number while using regular V Ray lights. If you have the IES info of your light, use them, if not. not big deal. Quality wise they will render the same. Try to use V Ray IES they render faster than Max IES. Link to comment Share on other sites More sharing options...
rajeshpr1 Posted July 16, 2015 Author Share Posted July 16, 2015 Sir, thank you so much. I am a beginner. I will disturb u again while I am rendering for other project. Link to comment Share on other sites More sharing options...
