Matt Sugden Posted July 17, 2015 Share Posted July 17, 2015 I need to create this effect in max, of a laser beam scanning over an object odd shaped object. I thought initially just using a vray light (long and thin rectangular), but it's not bright enough relative to the rest of the scene, and also when I make the light source invisible it is not casting the light like a clear beam very effectively. Any other ideas? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted July 17, 2015 Share Posted July 17, 2015 You could try using a standard direct light set to square distribution and set the shape of it to be very long and very thin. Or use a gobo in the texture slot for the light that is just a thin white line. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted July 17, 2015 Share Posted July 17, 2015 +1 for gobo, use projection map slot with a standard direct light to avoid too much spread. Also quite easy to render a volume light pass using this method if you wanted to. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted July 17, 2015 Share Posted July 17, 2015 a V-Ray light plane should do it, just adjust the Directional value, to a minimum or something that you like. Adjusting environment exposure should compensate your light/Laser with respect your environment. You can use V Ray glow to create a "Laser" glowing effect or render a light pass and add the glow in after effects or photoshop. What is GOBO any ways?? Link to comment Share on other sites More sharing options...
Stephen Thomas Posted July 17, 2015 Share Posted July 17, 2015 https://en.wikipedia.org/wiki/Gobo_(lighting) Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted July 17, 2015 Share Posted July 17, 2015 stef.thomas said: https://en.wikipedia.org/wiki/Gobo_(lighting) Thanku. Link to comment Share on other sites More sharing options...
