doraima Posted November 16, 2004 Share Posted November 16, 2004 Tutorials I found at Autodesk are good creating Cloth objects, but I was wondering if anyone knows good tutorials like tables, chairs, and lamps(all types of furniture). Lighting in lamps and around the scene are one biggie that I want to improve on. also, I want to manipulate drapes in this form located within the blue box http://jemalonzo2001.tripod.com/temp_screenshots/Draperies-08b.JPG Link to comment Share on other sites More sharing options...
Brian Cassil Posted November 16, 2004 Share Posted November 16, 2004 Would you mind pointing us to where the tuts you found for modeling drapery are? Link to comment Share on other sites More sharing options...
doraima Posted November 17, 2004 Author Share Posted November 17, 2004 this is the tutorial for making curtains or so called draperies, using Autodesk Viz and 3d max: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=3608022&linkID=982674 I figured how to manipulate it using the FFD on how I should design it for interior design. Link to comment Share on other sites More sharing options...
salman1karim Posted August 30, 2005 Share Posted August 30, 2005 Hi: I want to know how u create curtains and how give the fabric material on curtains? Please help me I am new designer in 3ds max Link to comment Share on other sites More sharing options...
doraima Posted August 30, 2005 Author Share Posted August 30, 2005 Salman, If you read this forum, it should show you steps how to create draperies. Also, it takes your problem solving skills and refer to the Help> Reference files -- if you are not famililar with the tools you are going to use. http://usa.autodesk.com/adsk/servle...2&linkID=982674 Link to comment Share on other sites More sharing options...
Sawyer Posted August 30, 2005 Share Posted August 30, 2005 I think a lot of us use a plugin that does CLOTH. Cloth, Simcloth, or Reactor are a few that I can think of. All are pretty easy to use once you get the idea down & I have found that each one does a certain type or simulation better. These are simulation plugins that create a cloth type object and let it interact with solid objects taking into account forces (gravity, wind etc.) This is for Simcloth. Its free. http://www.spot3d.com/simcloth/ Link to comment Share on other sites More sharing options...
salman1karim Posted September 4, 2005 Share Posted September 4, 2005 thanks for reply. i explain my works in small words. 1. draw rectangle and cylinder 2. break all vertices of rectangle 3. i apply the garment maker (clothfx plugins) 4. then apply clothfx 5. join cylinder with the rectangle using the garment tools lastly i change the gravity and other parameter but there is no effection means not like curtains. if i increae the gravity parameter then its moving down but if i decrease the gravity parameter like -ve value then it moving up. please help me how can i solve the solution. Link to comment Share on other sites More sharing options...
