mindaugasbucas Posted July 27, 2015 Share Posted July 27, 2015 Hello, i have a question is it possible to reduce primary bounce (Vray, 3ds max) on specific face. F.e. i have a white table and i want that one face of it get less light. Or should i apply slighty grey material to that specific face? Thank you in advance. Link to comment Share on other sites More sharing options...
ediskujovic Posted July 27, 2015 Share Posted July 27, 2015 I think you can. Right click on object, properties and reduce the GI if you want to reduce the bounces. Play with it to get the result. Sorry if I am wrong but i think this is how you do it. Sent from my HTC One using Tapatalk Link to comment Share on other sites More sharing options...
notamondayfan Posted July 27, 2015 Share Posted July 27, 2015 Or you could look at the problem, figure out what's happening and do it properly? My initial reaction would be to check materials (is it too white?), then lighting (have I got a spotlight directly lighting the table top?), then reflections (is the table reflecting the window / sky?). Messing around with GI bounces will lead to less realistic / accurate results, much in the same way scalling objects because they don't look "right". Link to comment Share on other sites More sharing options...
mindaugasbucas Posted July 27, 2015 Author Share Posted July 27, 2015 Hmm i think you right, i will try chek it maybe its really too white(; I asked cuz it was first thing which came to mind(; in the now i have more thing to look and make them correct, thank you(; Išsiųsta naudojantis SM-A500FU Tapatalk 4 Lt Link to comment Share on other sites More sharing options...
