yp Posted August 6, 2015 Share Posted August 6, 2015 Hi, anybody knows a script to generate a zdepth pass (along with other selected render elements, vray) from a selection of objects to use it as as displaced texture for quicker rendertimes and better scene handling? Kind of a one click solution for the common task: eg. set up a plane with scattered elements (eg. gravel), position a camera orthogonal to this plan, render out a zdepth pass with closest boundary to fit the objects. Then applied to a plane with vraydisplacement mod gives quite close results (except from looking to close and low angle) Setting this scene up manually is a little time consuming, may not be perfectly 90°, needs to be adjusted and is more or less limited to a vertical projection. A script could ease this process by maybe just selecting the objects and the script takes care of setting up camera and parameters - and could even simply place the camera orthogonal to the objects even if they are not horizontal only... I hope this explanation wasnt too confusing and even more I hope there IS some script like this out there and that someone can point me to it. Thanks in advance Link to comment Share on other sites More sharing options...
notamondayfan Posted August 10, 2015 Share Posted August 10, 2015 You could set-up 1 camera / scene / zdepth, and then drop in the new objects to be rendered. All I would do is make sure the height of the new objects is within the zdepth range (scale Z if needed), and it should render fine. No need for scripting really to be honest. Dean Link to comment Share on other sites More sharing options...
yp Posted August 12, 2015 Author Share Posted August 12, 2015 Hi Dean, thanks for your response. Yes, your're definitely right, don't know why I didn't think of this myself. Actually you need to set up the whole scene properly to have a correct diffuse lighting to get a correct and evenly lit diffuse texture along with the displacement! So even if it would be nice to just select a bunch of objects and run a script which generates a z-depth map and maybe even applies it properly after (corresponding displacement hight and so on..) this would / could be a problem. Anyway, to create some "displacement-texture" your advise works fine. Niko Link to comment Share on other sites More sharing options...
