Jim Mann Posted November 17, 2004 Share Posted November 17, 2004 This may yet be an issue with my camera rather than my capture method but here goes. I want to capture some video footage to dome some basic rotoscoping work in Combustion. I have been using Premiere pro for the capture from a JVC GR-DV700EK mini DV cam. EVerything is fine apart from the horrible jaggies that appear at the edge of moving objects. I am guessing that it has soemthing to do with fields but can't be 100% sure. Does anyone know if it is possible to capture footage from mini DV and get a smooth edge result that can be tracked and roto'd properly? Thanks in advance Jim Link to comment Share on other sites More sharing options...
Jim Mann Posted November 17, 2004 Author Share Posted November 17, 2004 example attached Link to comment Share on other sites More sharing options...
STRAT Posted November 17, 2004 Share Posted November 17, 2004 ur right. it is fields. but it's been so long since i used Premier i cant remember how to solve the problem. sorry Link to comment Share on other sites More sharing options...
Jim Mann Posted November 17, 2004 Author Share Posted November 17, 2004 Hi Strat, Do you know whether it is a limitation of the camera or the capture? I can get round it by scaling the footage 50% but then I am stuck with 360 wide footage. Jim Link to comment Share on other sites More sharing options...
STRAT Posted November 17, 2004 Share Posted November 17, 2004 as far as i remember it's a simple switch to check when importing or exporting. some of the videos i used to capture/create i remember literally being able to turn fields on/off for matching up. Link to comment Share on other sites More sharing options...
quizzy Posted November 17, 2004 Share Posted November 17, 2004 its under interpret footage: select upper fields first Link to comment Share on other sites More sharing options...
Jim Mann Posted November 17, 2004 Author Share Posted November 17, 2004 Cool, It is still interlaced when I capture but I can then export a de-interlaced version from Premiere. Thanks Jim Link to comment Share on other sites More sharing options...
