dostmeymo Posted August 10, 2015 Share Posted August 10, 2015 Hi guys, Any idea why I can't see Vray-mesh proxy when I right click? I'm using V-ray 3.20.01 on max design 2015 Thanks in advance Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 10, 2015 Share Posted August 10, 2015 Its not under the "convert to" tab on the bottomn? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 10, 2015 Share Posted August 10, 2015 I'm sure amongst the vray install files is a "register vray menu's" script that will add all the relevant menus? Link to comment Share on other sites More sharing options...
dostmeymo Posted August 10, 2015 Author Share Posted August 10, 2015 Hi, Nicolai, No it's not under covert to. There's only (convert to editable Mesh, Poly, Patch and Deformable Gpoly) Chris, I couldn't find "register vray menu's" script amongst the vray install files Thanks Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 10, 2015 Share Posted August 10, 2015 By default the V-Ray menus are automatically registered when V-Ray is installed (there is an option about this in the V-Ray installer). However, sometimes the menu items can be lost if the 3ds Max menu system is reset - for example, when switching between different 3ds Max work spaces. In this case, the V-Ray menus can be registered manually with the registerVRayMenus() MaxScript command. http://docs.chaosgroup.com/display/VRAY3/Menu+integration# Link to comment Share on other sites More sharing options...
dostmeymo Posted August 10, 2015 Author Share Posted August 10, 2015 Okay I understand what happened but I'm still searching for how to register Vraymenus! any idea! Thanks Chris Link to comment Share on other sites More sharing options...
dostmeymo Posted August 12, 2015 Author Share Posted August 12, 2015 Well I have reinstalled V-ray and everything is okay now Link to comment Share on other sites More sharing options...
pixelsriram Posted March 14, 2016 Share Posted March 14, 2016 Hi all Can we get Proxy things with applied vray material ? Please do reply ! Sriram Link to comment Share on other sites More sharing options...
pixelsriram Posted March 14, 2016 Share Posted March 14, 2016 Do Re Install your vray software . Please enable register vray menus during the installation. Sriram Link to comment Share on other sites More sharing options...
