karayong Posted August 13, 2015 Share Posted August 13, 2015 Can anyone tell me why the colors turn out like this during the render? Link to comment Share on other sites More sharing options...
michaelholzinger Posted August 13, 2015 Share Posted August 13, 2015 i think you are just viewing the sample rate render element and not the RGB pass.... Link to comment Share on other sites More sharing options...
karayong Posted August 13, 2015 Author Share Posted August 13, 2015 This is how the render window looks like. May I know how to switch it to the RGB pass? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 13, 2015 Share Posted August 13, 2015 Any specific reason you are using the default max frame buffer? Enable the vray frame buffer in you render settings and use that instead. In the vray frame buffer it is easy to switch between the different render elements. Link to comment Share on other sites More sharing options...
michaelholzinger Posted August 13, 2015 Share Posted August 13, 2015 another reason could be that you just see an old render in the frame buffer - clear the frame buffer and the render again... (with the "X" button you clear it...) Link to comment Share on other sites More sharing options...
LuisaEchavarria Posted December 27, 2023 Share Posted December 27, 2023 You can download coloring pictures from: https://dibujosparacolorearwk.com/ - a website that provides high-quality coloring images. Link to comment Share on other sites More sharing options...
