rhlkvr15 Posted August 31, 2015 Share Posted August 31, 2015 hi forum, I Rendered a 32bit Open EXR Image Sequence in 3ds max and when I edit it in After Effects using Magic Bullet Looks, in the main view it looks fine, but when i open the footage in Magic Bullet looks the gamma is way off (footage is dark), can anyone help me with this. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted August 31, 2015 Share Posted August 31, 2015 Is your composition set to 32-bit? It will tell you at the left hand side under your list of project assets. Link to comment Share on other sites More sharing options...
kriscabrera Posted August 31, 2015 Share Posted August 31, 2015 yea set your comp to 32bit you should be ok, i had the same issue and i had to compensate for it in MB but just set your comp to 32 and you will be good Link to comment Share on other sites More sharing options...
rhlkvr15 Posted September 1, 2015 Author Share Posted September 1, 2015 Really appreciate for the reply guys, But i have set my project to 32bit and my image sequences are exr Files rendered from 3ds max, also attached the screen shots for the same, but MB window still looks dark. Link to comment Share on other sites More sharing options...
kriscabrera Posted September 1, 2015 Share Posted September 1, 2015 hmmm.... thats interesting, what gamma are you using out of 3dsmax? i will look tonight when i get home and show my setup Link to comment Share on other sites More sharing options...
rhlkvr15 Posted September 2, 2015 Author Share Posted September 2, 2015 Hi Kris, Thank you for the reply I work with gamma 2.2 in 3ds max and save the file as open exr. Still couldn't solve the issue. Link to comment Share on other sites More sharing options...
