Terri Brown Posted September 4, 2015 Share Posted September 4, 2015 Hi guys, Just wondering if anyone has an answer to this one: My usual workflow when compositing in PS is to render out a few elements (of which Wire Color is one) of my final image, and to re-render the Wire Color with glass switched off. The Wire Color pass with glass turned ON always has the glass pane shown as totally opaque. All of a sudden though the element is rendering with a slight opacity, like this: As you can see the glass pane on the left is transparent. I'd prefer it back to a solid color. Any idea on how to change that? Is it a material option? A depth issue? I have Override Depth in Global render options checked to 20. Thanks guys Link to comment Share on other sites More sharing options...
Terri Brown Posted September 4, 2015 Author Share Posted September 4, 2015 Sorry forgot to mention: 3DS Max 2014, Vray 3 Link to comment Share on other sites More sharing options...
maxryhan Posted September 4, 2015 Share Posted September 4, 2015 That's because of "Affect all channel " is enabled for the glass material under Affect Channels parameter, so all channels and render elements will be affected by the transparency of the material... change it to Color+alpha and the wirecolor would be okay again cheers. Link to comment Share on other sites More sharing options...
James Vella Posted September 4, 2015 Share Posted September 4, 2015 in the refraction material for the glass make sure instead of all channels or with alpha it is color only Link to comment Share on other sites More sharing options...
Terri Brown Posted September 4, 2015 Author Share Posted September 4, 2015 you clever man. thank you. Link to comment Share on other sites More sharing options...
