Fëanor Posted September 7, 2015 Share Posted September 7, 2015 Hi everyone! I've just upgraded to vray 3.20, and I'm having this weird problem. This is a crop of a final render where you can see the grainy reflection: As you can see, the top of the folder looks all wrong. I tried increasing the reflection subdivs, but I had no luck. The weird thing is that the problem disappears when I do a region render: This is my first time starting a scene from scratch in Vray 3.20. I never had this problem using the same materials in vray 2.4, so that's why I think that maybe this has something to do with one of the new vray render options? I'm using Irradiance map and Light cache. Thanks a lot and excuse my broken english. Link to comment Share on other sites More sharing options...
timothyhanson Posted September 13, 2015 Share Posted September 13, 2015 Since the release of Vray 3 you really don't need to use light caching hacks anymore. Go brute force / brute force for everything because it is fast enough to handle it. Not only will you never have flickering in your animations, but it is a smoother render. Give that a try, and also look into clamping max ray intensity to 20 in your global advanced options. Link to comment Share on other sites More sharing options...
