adamsargeant Posted September 12, 2015 Share Posted September 12, 2015 Hi all. New member on here despite being a long time lurker. Bit of a strange one, but probably really simple to sort. I have my Vray sun set where i want it and the target likewise, yet the shadows being cast do not reflect this and no matter where i place the sun, the shadow does not change. The only other scene lighting i have is a dome light. I have included an image to show what i mean. Any help appreciated. Thank you. image sharing sites Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 12, 2015 Share Posted September 12, 2015 I ca see from your irradiance map pass that there is 2 light sources in your scene, you have an V Ray sun and a dome light with an HDRI on it?? if so and your HDRI is good it will create solid shadows, if so you need to align you V Ray sun with the sun within your HDRI. Search on google for V Ray sun + HDRI you find several tutorial explaining how to do this. Link to comment Share on other sites More sharing options...
adamsargeant Posted September 13, 2015 Author Share Posted September 13, 2015 Hi Francisco. I do have a HDRI. I have two different models in the scene and i had set the HDRI to suit the other model. Totally forgot that the 'light' area would need to be re positioned to fall in line with the altered sun position. I turned the HDRI off as a test and the shadows disappeared so your theory was spot on - Thank you. Adam Link to comment Share on other sites More sharing options...
