michaelberens Posted September 22, 2015 Share Posted September 22, 2015 Hello everyone, just received my new workstation which i ordered including assembly and testing by the retailer. I think the decision to order the Noctua NH-D15 (with mobo asus x99-a usb 3.1) was not the best one. Anyway - beside that, i think that the assembly wasn't done properly. Please take a look at the picture and tell me what you think about it. It looks really not good for me. Already RMA-ed the system. Thanks, Michael Link to comment Share on other sites More sharing options...
John Dollus Posted September 22, 2015 Share Posted September 22, 2015 hard to tell from the photo for certain but if the heatsinks are actually touching the video card and causing it to bend, that's not good. The card needs to be relocated or more suitable cooling installed that will allow for proper clearance Link to comment Share on other sites More sharing options...
Nikolaos M Posted September 22, 2015 Share Posted September 22, 2015 (edited) You could move the gpu to another pcie x16 slot (try the 3rd one from the top). The first slot is unsusable with this cooler in other motherboards too http://www.pcper.com/reviews/Motherboards/EVGA-X99-Classified-Motherboard-Review/CPU-Cooler-Fit-Included-Accessories Edited September 22, 2015 by nikolaosm Link to comment Share on other sites More sharing options...
numerobis Posted September 22, 2015 Share Posted September 22, 2015 Yes, you should use a different PCIe slot, as Nikolaos said. Link to comment Share on other sites More sharing options...
michaelberens Posted September 22, 2015 Author Share Posted September 22, 2015 Yes, i think the first pcie x16 slot is unusable due to the backplate of the gtx 970 strix. Also mentioned in this review of the asus x99-a . I should have read this before. Moving the gpu to another pcie x16 slot? I thought also about this option, but then read this: "Note: It is recommended that you install the graphics card into the primary PCI Express x16 slot. If you install the graphics card into the secondary slot, your system may not recognize the graphics card and there will be nothing displayed on the monitor. Also note that on some motherboard SbIOS, the physical location of the primary slot can be configured when there are more than one PCI Express x16 slots." > GTX 970 User Guide Wouldn't moving to another pcie-slot than the primary one also reduce the performance of the gpu? Just heard something like that... Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 22, 2015 Share Posted September 22, 2015 If you bough that PC build, you should not touch it, take it back to the store and tell them to do a good job! that is un acceptable, they are the one who has to deal with the BIOS setup for video cards and such. Even though changing a video card to other slot is not a big deal really, if you do it your self you will break the warranty of your retailer and if anything else happens they will wash their hands with it. So even if it is a pain in the neck just take it back and let them deal with it. That was a very bad decision to put that card there, The Noctua is a excellent cooler but in that setup it is too big, they should recommended some alternative. best luck. Link to comment Share on other sites More sharing options...
numerobis Posted September 22, 2015 Share Posted September 22, 2015 (edited) fco3d said: If you bough that PC build, you should not touch it, take it back to the store and tell them to do a good job! Yes, that's true. I thought he had bought the parts... @Michael: Sorry i missed the part that you already RMAed the system. Where did you buy it? Looks like someone who should be avoided when it comes to assembling of PCs... Concerning the PCIe-slot. The X99A has two PCIe 3.0 x16 slots. Normally there shouldn't be any problems running the card in the second one. I have it this way in several machines where the card doesn't fit into the first PCIe slot because the cooler is too large and i never had any problems... but maybe there is something special regarding this board (but i don't think so). Edited September 23, 2015 by numerobis Link to comment Share on other sites More sharing options...
michaelberens Posted September 23, 2015 Author Share Posted September 23, 2015 I bought the system at mindfactory.de. They called me today and told me that they have "straightened" the cooler, tested the system and everything should work fine now. I didn't accept this and wanted them to replace all affected parts like CPU, Mobo, Cooler and GPU. After a little bit of negotiation they agreed to replace the cooler and after a little bit more of negotiation they also agreed to replace the GPU and run a stress test for all parts. I accepted this. Should i have been more insisting? I also sent some photos of the "disaster" to noctua support. They told me to return immediately the system to the retailer what i already had done. They also wrote an additional note that the NH-D15 in combination with the X99-A provides rather little clearance between GPU and the cooler but is generally no problem. To prove this statement they attached the following photo: So, still waiting and hoping that the parcel carriers will be careful. Link to comment Share on other sites More sharing options...
