ianmoran Posted September 23, 2015 Share Posted September 23, 2015 Studio/Institution: PersonalGenre: Residential InteriorSoftware: Maya VrayDescription: Hello guys, If you have a few spare minutes, please offer a little critic to this kitchen design I am working on. My main question is, is the light too bright? Lighting is something that I feel is really weak with me so I am making more effort to focus on it. Thank you. Ian Link to comment Share on other sites More sharing options...
Sketchrender Posted September 23, 2015 Share Posted September 23, 2015 If I was to say anything. I would change the seats, lights, window and curtains. Ideas and references are very important to copy and inspire. https://www.pinterest.com/search/pins/?q=kitchen%20modern&term_meta%5B%5D=kitchen%7Ctyped&term_meta%5B%5D=modern%7Ctyped Link to comment Share on other sites More sharing options...
Andres Saarnak Posted September 23, 2015 Share Posted September 23, 2015 Maybe it`s even too dark? White furniture can be pretty bright. And I agree with philip kelly, its best to look references. https://www.pinterest.com/search/pins/?q=kitchen%20white&term_meta%5B%5D=kitchen%7Ctyped&term_meta%5B%5D=white%7Ctyped&remove_refine=modern%7Ctyped Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted September 23, 2015 Share Posted September 23, 2015 I would consider a darker exposure for the environment and then balance out the brightness with artificial lights in the ceiling. I see this a lot in low-environment interior photography, even in the daytime. Both links from the previous posters show examples of this. And then use Post to brighten shadows and add contrast in your black point. You can't really render the bracketed exposures so you need to just save as an EXR and do some post work on it. Link to comment Share on other sites More sharing options...
ianmoran Posted September 24, 2015 Author Share Posted September 24, 2015 Thanks guys... The reference images you posted are really helpful. I think your description in very helpful Corey. Thank you. I agree with your advice and will try this once I've observed some more references. These are some of the references I was using up to date... I thought these were a bit dark so I went brighter.... A bit too far though... Link to comment Share on other sites More sharing options...
Larissa Holderness Posted September 24, 2015 Share Posted September 24, 2015 I don't think it is too bright. Rather, the whites and vivid colors (green, yellow, red) are blown out and there isn't enough contrast in the light intensity. Never use 100% white in your render ... they lose definition. Link to comment Share on other sites More sharing options...
brendanrogers Posted September 24, 2015 Share Posted September 24, 2015 Looks ok to me for the brightness. Maybe make the background outside window a little less white? Link to comment Share on other sites More sharing options...
SgWRX Posted September 25, 2015 Share Posted September 25, 2015 i kind of think it's not bright enough. if you have photoshop, add a curves adjustment layer and grab a point on the line near the middle of the brightest 1/4 and move it up (ex. input 229 output 245) then grab another point down in the darkest 1/4 and flatten it out (ex. input 54 and output 67). doing this though, i would tone down the chairs and tone down the colored lamps, except maybe the yellow lamp it seems to handle the curves OK as does the back wall. Link to comment Share on other sites More sharing options...
