akshayarora Posted October 3, 2015 Share Posted October 3, 2015 Hello All, Actually I recently started working with gamma 2.2 linear workflow ,did a render and got black patches when opened in photoshop . Can anyone help out . Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted October 4, 2015 Share Posted October 4, 2015 Thats not gamma isue. To me it looks like you are clipping the colors in your image. Are you using exr or hdr images as output? Or simple JPG? For a correct flexible linear work flow you need to save your image at float point Link to comment Share on other sites More sharing options...
akshayarora Posted October 5, 2015 Author Share Posted October 5, 2015 Thats not gamma isue. To me it looks like you are clipping the colors in your image. Are you using exr or hdr images as output? Or simple JPG? For a correct flexible linear work flow you need to save your image at float point Am saving in Targa , Not getting exr format there ,only .vrimg is available . also am little confused some tutorials highligting -gamma to use as (0.454) and some are using override on materials as 2.2 . Can you mark me a specific tutorial which I can follow and understand . Thanks Link to comment Share on other sites More sharing options...
akshayarora Posted October 5, 2015 Author Share Posted October 5, 2015 Thats not gamma isue. To me it looks like you are clipping the colors in your image. Are you using exr or hdr images as output? Or simple JPG? For a correct flexible linear work flow you need to save your image at float point Screenshot of the setting which am using , One more thing ,the render which is visible in frame buffer window is dark and exr file is bright , Don't know how to work on exr file which is supposed to save finally ..please help .. Link to comment Share on other sites More sharing options...
pradeepvt Posted October 5, 2015 Share Posted October 5, 2015 It May be noice. You Will increase your noice threshold 0.005 Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 5, 2015 Share Posted October 5, 2015 When you save to EXR you need to Override the output gamma to 1.0 in the save menu. There are other ways to do it, but this is the most straight forward. Link to comment Share on other sites More sharing options...
