extrude modifier missing in 3ds max
kevinossia
I wanted to try using the extrude modifier in 3ds max for the first time as it seems to be the solution to my problem, but I can't find the extrude modifier in the modifier list.
I looked in the standard menu and went to Modifiers-->Mesh Editing, and the extrude modifier is there, but I can't use it. It is grayed out.
Any ideas? How do I fix this?
If you are saying that you have model that is modeled out of a single plane (no thickness at all) then all you would want to do is use a Shell Modifier.
With shell the inner and outer amounts aren't necessarily properly labeled, as in outer amount can often times effect the inner portion of your model, but just roll with the visual feedback. The other thing to note with Shell is that the option to "Straighten Corners" is often necessary.
