luisguimaraes Posted October 6, 2015 Share Posted October 6, 2015 Hello, I am developing an image of an building, and the facade have a lot of glass. For lighting i am using a HDRI, that give me some reflections of the sky in the glass. The problem is the black line of the ground (Skyline) that appear on my window also. There is a way to take out that reflection? Thanks Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 6, 2015 Share Posted October 6, 2015 Your HDRI can either be reflected or not but you can't select areas within the HDRI that are or aren't reflective. One option would be to put a plane on your ground plane and adjust it's color so it works better with your scene. Link to comment Share on other sites More sharing options...
luisguimaraes Posted October 7, 2015 Author Share Posted October 7, 2015 Your HDRI can either be reflected or not but you can't select areas within the HDRI that are or aren't reflective. One option would be to put a plane on your ground plane and adjust it's color so it works better with your scene. Ok, i made the plane in the ground and fixed the problem. Thanks for helping.. Link to comment Share on other sites More sharing options...
