Kirsten Zirngibl Posted October 11, 2015 Share Posted October 11, 2015 (edited) Hi, I have a crapload of unique materials in my scene, and wish to go in and shift the hue/brightness for a bunch of them (but not all of them). Some of them are are multi/sub object materials, others aren't. I realize I can shift+drag the color correct map within the Slate Editor to copy it, then de-link it and apply it to another map, but I need to do this with so many materials that it would get really tedious. (Why no right click copy-> paste for maps at least?) I've searched Scriptspot but nothing working so far... I tried the "ColorCorrect" plugin, but that only seems to be work for one diffuse map at a time which defeats the purpose, and I hear it has memory leak issues. Also there's no version of it for my version of Max (2014). I also found this script. It's designed for Vray though, which I don't use. My dream, as partially described in the 2nd link, would be the ability to select several objects and then run some kind of utility that applies a color correction map to each diffuse map... and then shifts the hue/sat/brightness/curves of ALL of them, ideally with some kind of slider UI. Even if I can't do this via scripts, seems like there should be a way to apply a color correct to all the materials within a multi/sub object at LEAST. I'm actually really surprised there isn't a native way to do this in Max. (Or maybe there is, I'm admittedly a texture noob.) Thanks in advance. EDIT: Got a script. Posting here for any future folks with this need. (Thanks u/Heilandzack over on r/maxscript!) Also, for an alpha map version, I went through the code and substituted "diffuse" with "opacity" and it totally works. /* --------------- color correct materials for selected objects ----------------- Should work for standard and multisub-materials Flow: Get materials from selected objects if there is a mutlimat, get all submats instead and remove the mutlimat itself remove duplicates from array if there is a map in the diffuse channel, create a new cc node with the new settings and use the diffusemap as source assign the cc node to the diffuse slot */ --- get materials from selection mymaterials = #() for obj in selection do ( if obj.material != undefined do appendifunique mymaterials obj.material ) --- check for multisubmtls and collect the submtls mysubmaterials = #() for a=1 to mymaterials.count do ( if classof mymaterials[a] == Multimaterial then -- if multisubmtl, then ( for b=1 to mymaterials[a].materialList.count do --- loop through submtls ( if mymaterials[a].materialList[b] != undefined then appendifunique mysubmaterials mymaterials[a].materialList[b] -- collect submtls ) ) ) -- delete multisubs from matarray for a=mymaterials.count to 1 by -1 do ( if classof mymaterials[a] == Multimaterial then deleteitem mymaterials a ) -- append the submtls for a=1 to mysubmaterials.count do ( appendifunique mymaterials mysubmaterials[a] ) print mymaterials -- see whats in the diffuse slot for mymaterial in mymaterials do ( -- make sure its a standard material if classof mymaterial == Standardmaterial then ( --- make sure the diffuse slot is not empty if mymaterial.diffuseMap != undefined then ( -- remember the map in the diffuse slot mymap = mymaterial.diffuseMap -- create a new cc node and wire it ccnode = ColorCorrection() ccnode.Map = mymap -- set cc settings ccnode.hueShift = 0.0 ccnode.saturation = 0.0 ccnode.tint = (color 0 0 0) ccnode.tintStrength = 0.0 /* ccnode.rewireMode (Rewire_Mode) : integer ccnode.rewireR : integer ccnode.rewireG : integer ccnode.rewireB : integer ccnode.rewireA : integer ccnode.hueShift : float ccnode.saturation : float ccnode.tint (Hue_Tint) : fRGBA color ccnode.tintStrength (Hue_Strength) : float ccnode.lightnessMode : integer ccnode.contrast : float ccnode.brightness : float ccnode.exposureMode (Lightness) : integer ccnode.enableR : boolean ccnode.enableG : boolean ccnode.enableB : boolean ccnode.gainRGB (LightnessGainRGB) : float ccnode.gainR (LightnessGainR) : float ccnode.gainG (LightnessGainG) : float ccnode.gainB (LightnessGainB) : float ccnode.gammaRGB (LightnessGammaRGB) : float ccnode.gammaR (LightnessGammaR) : float ccnode.gammaG (LightnessGammaG) : float ccnode.gammaB (LightnessGammaB) : float ccnode.pivotRGB (LightnessPivotRGB) : float ccnode.pivotR (LightnessPivotR) : float ccnode.pivotG (LightnessPivotG) : float ccnode.pivotB (LightnessPivotB) : float ccnode.liftRGB (LightnessLiftRGB) : float ccnode.liftR (LightnessLiftR) : float ccnode.liftG (LightnessLiftG) : float ccnode.liftB (LightnessLiftB) : float ccnode.printerLights (LightnessPrinter) : float */ -- put the cc node to the diffuse slot mymaterial.diffuseMap = ccnode ) else print "nothing in diffuse slot" ) ) Edited October 12, 2015 by kirstenzirngibl Link to comment Share on other sites More sharing options...
