kirilneshev Posted October 11, 2015 Share Posted October 11, 2015 Hello everyone , I was having problems lately with the cornice /molding (premade from 3dsky) I don`t know how to make it smooth for the outer corners ,can someone help me with that problem or give me a tutorial .I am kinda new to 3ds max I was using "follow me" in sketchup . Thank you in advance Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted October 11, 2015 Share Posted October 11, 2015 If it is an editable poly, either play around with smoothing groups (to make it appear smooth, without adding additional polys) or chamfer the edges. Link to comment Share on other sites More sharing options...
kirilneshev Posted October 11, 2015 Author Share Posted October 11, 2015 Thank you for the reply Nicolai Bongard Maybe I did not ask the question right, the object itself is fine but I don`t know how to use it on corners because its only 1 object that is straight there are no corner cornices its just 1 that is like a line. IF the room is a square its fine I put them in one another but if there are rooms that have walls with an angle of some degree I don`t know how to make them. Link to comment Share on other sites More sharing options...
kirilneshev Posted October 11, 2015 Author Share Posted October 11, 2015 Here are some pics of the problem I am talking about Link to comment Share on other sites More sharing options...
Amen Posted October 11, 2015 Share Posted October 11, 2015 Hi, You can use loft, sweep, bevel profile or the symmetry modifier to get the object around the corner. Link to comment Share on other sites More sharing options...
RyderSK Posted October 11, 2015 Share Posted October 11, 2015 Amen said: Hi, You can use loft, sweep, bevel profile or the symmetry modifier to get the object around the corner. These solutions are the best (we do a lot of this stuff...). But sweep is only if your stucco has no repeated detail across the surface. Then the solution is symmetry modifier (with 45° rotation of gizmo), but correct the smoothing groups afterwards. Link to comment Share on other sites More sharing options...
