miauu_u Posted October 18, 2015 Share Posted October 18, 2015 (edited) Polyline Pro is an easy to use yet powerful and intuitive tool which provides a clear and efficient user interface to create splines precisely with measurements and angles in a manner similar to AutoCAD. The main purpose of Polyline Pro is to bring the spline drawing in 3dsMax at a higher level. With Polyline Pro you can: draw splines in Orthographic, Polar, Arc and Freehand modecreate points using Absolute or Relative coordinatesuse direct distance entry - point in desired direction and type the length and/or the angle to create a segmentuse guides and tooltipsuse short commands for quick access to almost all of the featuresuse Object Snaps to mark certain points/lines and continue to draw in their projection or intersectiondraw spline using World Coordinate System or User Coordiante System For more information go here. Edited December 13, 2016 by miauu_u Link to comment Share on other sites More sharing options...
miauu_u Posted November 23, 2015 Author Share Posted November 23, 2015 Polyline Pro version 1.2 is available What is new: - While drawing arc you can set the position of the second point - You can create perpendicular alignment paths to arbitrary lines/segments Link to comment Share on other sites More sharing options...
miauu_u Posted December 14, 2015 Author Share Posted December 14, 2015 Polyline Pro 1.3 is released. Changelog: - While drawing arc you can set the radius of the arc Link to comment Share on other sites More sharing options...
miauu_u Posted January 11, 2016 Author Share Posted January 11, 2016 Polyline Pro version 1.4 is released Changelog: - added support for Perspective, Orthographic and Grid(Top and Display Planes only) viewports. Link to comment Share on other sites More sharing options...
miauu_u Posted December 13, 2016 Author Share Posted December 13, 2016 Polyline Pro is updated to version 1.7. Changelog: - Added support for User Coordinate System. Link to comment Share on other sites More sharing options...
