journeymenarts Posted October 23, 2015 Share Posted October 23, 2015 So I changed the gamma output setting from the original file that I had, and not I cannot seem to get these darkspots out... Can Anyone pleas help. Much appreciated Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 23, 2015 Share Posted October 23, 2015 It's your GI settings you need to adjust them to smooth it out. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted October 23, 2015 Share Posted October 23, 2015 Gi too low and maybe double geometry on those areas. Check normals too. Link to comment Share on other sites More sharing options...
journeymenarts Posted October 23, 2015 Author Share Posted October 23, 2015 these are my settings Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted October 23, 2015 Share Posted October 23, 2015 how many lights you have inside?? if you had to crank that much your gamma, it seems your room is barely lit form the outside light only. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted October 23, 2015 Share Posted October 23, 2015 It could also be a non-vray material issue. Anything not a vray material can cause goofy GI sampling. Link to comment Share on other sites More sharing options...
augustobohm Posted October 23, 2015 Share Posted October 23, 2015 Hi, i had this problem once, Try to render a brighten scene, with invisible plane lights on the windows, you can also increase your camera iso or decrease the shutter speed, but i think you'll need more than 1250 subdivis in your light cache, put something like 2500. Post the new render so we can see the results. Hope it helps! Link to comment Share on other sites More sharing options...
RyderSK Posted October 24, 2015 Share Posted October 24, 2015 Your GI settings are OK, I would strongly think this is by incorrect light setup. 1)Turn ALL lights off, and create 'default' Sun&Sky. See if problem persist. Link to comment Share on other sites More sharing options...
