aggregate cpu multiple cpu vs single
i know that single threaded apps benefit from higher clock speeds (that applies to multi-threaded apps too :) ). i guess the trick is to find balance between app performance and rendering performance...
so a single 6 core cpu overclocked giving 5ghz vs. dual 6 core cpus overclocked to 3.8ghz. the aggregate is 45.6ghz vs 30ghz.
seems to me, the dual 6 core is going to give better cpu rendering performance.
(both cpu's would be hyperthreaded, so 12 buckets rendering vs 24 buckets).
any thoughts?
thanks,
1. I think you will have a hard time to find a Haswell-E that does more than 4.5GHz at reasonable voltages and temps.
2. You can overclock the cache (uncore) of Haswell-CPUs, which can give you some additional performance. Maybe up to 5-7% at the correct ratio, depending on the chip and your board (OC socket)
3. Dual CPU systems can't be overclocked (only a few percent using the BCLK). Only older ones based on socket 1366 (E5-X56xx) using some special boards.
4. There is an overclockable 8-core (5960X)
Edited by numerobis
