V-ray and Sketchup- Strange Reflection Issue
mrbawkbachgawk
I've been having this re-occurring reflection issue in sketchup vray renders. There appears to be a circular reflection/shadow that dominates the facade relative to where the camera placement is(see attached image). When I back up from the facade and re-render the circle becomes larger. I don't think this is the sun for either the sketchup sun or the HDR map as they are located in a different direction as the facade is facing. Please let me know if you have any ideas of what's causing this and what might fix it. I cant be the only one! Thanks!
It seems as if the issue has come back. Maybe my view angle had something to do with it. I am not using a Dome light however I tried one and had the same problem. I think it is an issue with the material parameters but I'm unsure as to what settings will resolve this. I've gone way high and way low on the IOR.
