Morne Erasmus Posted November 6, 2015 Share Posted November 6, 2015 Hi all Very old threads are suggesting Rhino > dwg and then import the dwg into Max is the best workflow. Any newer info on this? Dwg and 3ds works, I was just wondering if anybody has a "best method" kind of thing that ideally will keep all UVs and bring in the textures etc (keeping in mind I may have to go through a few design iterations by re-exporting the Rhino files Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 6, 2015 Share Posted November 6, 2015 I would probably do dwg and use the file link in Max so you can keep all of your materials assigned in Max each time you update the link. Link to comment Share on other sites More sharing options...
Simon Moir Posted November 8, 2015 Share Posted November 8, 2015 (edited) I've tried loads of things, settled on: 1. Export to dwg, make sure Rhino converts all geometry to meshes in the export options. I usually set the quality / density all the way up. Seems to do a better job of meshing Rhino models than Max. 2. In Max, apply a UVW Mapscaler modifier, set it to 1m. 3. I often use auto edge to clean up the viewport. Everything is mapped Real-World Scale and on layers, but I've had no luck keeping the link live or grabbing textures. Edited November 8, 2015 by sjmoir Link to comment Share on other sites More sharing options...
Nic H Posted November 8, 2015 Share Posted November 8, 2015 rhino - max is a total nightmare as simon said - export to high res DWG and then remodel it all. Link to comment Share on other sites More sharing options...
