jodestroy Posted November 25, 2003 Share Posted November 25, 2003 How can i avoid the lights comming from the outsoide sun ....around the edge of a room.... this is my first radiosity rendering..... thanks a lot jean Link to comment Share on other sites More sharing options...
smoke3dstudio Posted November 25, 2003 Share Posted November 25, 2003 First Check if there is no gap between wall, floor or ceiling. I guess it's not a radiosity problem. The light from outside that leaks into the edge of the room may be caused by the shadow bias. I suggest you better use either raytrace or advanced raytrace shadow for sunlight rather than shadow map and reduce its Bias to 0. Link to comment Share on other sites More sharing options...
jodestroy Posted November 25, 2003 Author Share Posted November 25, 2003 here are my rendering..... :-( http://www.cgarchitect.com/forum/filepush.asp?file=imagebadr Link to comment Share on other sites More sharing options...
jodestroy Posted November 25, 2003 Author Share Posted November 25, 2003 oops .... how can i insert pic. in this forum ... sorry i'm a newbie Link to comment Share on other sites More sharing options...
smoke3dstudio Posted November 25, 2003 Share Posted November 25, 2003 Chk the link again, may be it's a wrong spell. Link to comment Share on other sites More sharing options...
jodestroy Posted November 25, 2003 Author Share Posted November 25, 2003 i think this time i got the good pic... http://www.cgarchitect.com/forum/filepush.asp?file=badradiositysetting_1.jpg Link to comment Share on other sites More sharing options...
jodestroy Posted November 25, 2003 Author Share Posted November 25, 2003 here is the image http://www.cgarchitect.com/forum/filepush.asp?file=imagebadradiosity_2.jpg Link to comment Share on other sites More sharing options...
jodestroy Posted November 25, 2003 Author Share Posted November 25, 2003 if i reduce the shadow bias and render again, it's not working... Do i have to start the radiosity process again before.... ??? Link to comment Share on other sites More sharing options...
smoke3dstudio Posted November 25, 2003 Share Posted November 25, 2003 From the picture, I think the light around the edge is proberbly from the direct illumination. I don't think it's the radiosity problem. I also face this problem so many times though I have changed the bias. There is a way to avoid. See from the picture, the opening/window of the room seems to be small, so when you put the sunlight outside, just make the light's hotspot and fall off to be fitted to the window size. For example, if your window size is 1000mmx600mm, then the fall off size is about 600mm (radius). So the light will not affect any area but only come through window. Link to comment Share on other sites More sharing options...
smoke3dstudio Posted November 25, 2003 Share Posted November 25, 2003 Oh!!!! sorry, I see you didn't use render the direct illumination. You use "reuse direct illumination from radiosity solution" right? I've not been to closed with the radiosity for a long time. I think you may need to set the mesh subdivision again. Just make the mesh size smaller. Link to comment Share on other sites More sharing options...
