alexburlakov Posted November 23, 2015 Share Posted November 23, 2015 Hello, I am trying to set up material for leafs but have some issues. I put a mask for transperancy and it works fine, but when I add reflection layer masked area becomes visible as a light transparent color. Does anybody know how to fix it? Thanks Alex Link to comment Share on other sites More sharing options...
mowstn Posted November 30, 2015 Share Posted November 30, 2015 Apply a reflection map that is black where your leaf ends and put it in reflection map slot. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 30, 2015 Share Posted November 30, 2015 or simply use a standard "mask" map to clip your reflection before plugging it into your material. Link to comment Share on other sites More sharing options...
mowstn Posted November 30, 2015 Share Posted November 30, 2015 "plugging" sadly isn't possible with v-ray for sketchup - no node based mat editor. cheers. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 30, 2015 Share Posted November 30, 2015 My mistake.... I use the "Today's Posts" instead of the individual forum topics. I missed that you are working in Sketchup. Link to comment Share on other sites More sharing options...
yehonatanfrandzel Posted February 24, 2016 Share Posted February 24, 2016 I'm facing the same problem of not being able to mask reflections completely... Did you ever find a solution? Link to comment Share on other sites More sharing options...
yehonatanfrandzel Posted February 24, 2016 Share Posted February 24, 2016 I think I've figured it out! (seconds after posting the above question, but hours after searching for how to do this correctly ). 1. Under reflection map with TexFresnel chosen - Under the map for (reflection) IOR enter your transparency mask image. (don't touch refraction IOR) 2. change the color of Perpendicular to something other than white if you wish to reduce the reflection. Can also be done without the Fresnel: 1. Under the map for reflections choose TexBitmap. Enter your mask image in there. 2. change the amount of reflection by changing the number beside the map. Hope this helps someone Link to comment Share on other sites More sharing options...
ch1le Posted September 9, 2016 Share Posted September 9, 2016 I have a similar issue with getting material ID pass, sadly, clipped areas are some funky colour and i cant get good selections. A fix would be much appreciated. Link to comment Share on other sites More sharing options...
