adamsayash Posted November 24, 2015 Share Posted November 24, 2015 How to enable "CopyPasteObjects.mcr" script in 3ds max 2015? Link to comment Share on other sites More sharing options...
Stephen Thomas Posted November 24, 2015 Share Posted November 24, 2015 If it's the one I'm thinking of, after running the script go into Customize User Interface then Category / CG_Tools. I dragged the copy and paste commands to one of my quad menus so I can access via a right click. Link to comment Share on other sites More sharing options...
martinhoura Posted November 24, 2015 Share Posted November 24, 2015 good rule is to open up the scripts before installing, they usually have some instructions at the beginning like this one --INSTALLATION: -- 1. Click Maxscript / Run Script and choose wherever you downloaded this file to -- 1a. It will seem like nothing happened but that's exactly what it should do, you now need to assign a shortcut to it -- 2. Click Customize / Customize User Interface / Keyboard (tab) -- 3. Change the Category to "CG_Tools" -- 4. Click "Copy Objects to File" and change its Hotkey to something, maybe Ctrl+Alt+C .Click Assign -- 5. Click "Paste Objects from File" and change its Hotkey to something, maybe Ctrl+Alt+V. Click Assign -- 6. Click Save and save your custom UI settings to a file, do yourself a favor and don't use the default. -- 7. That's it. Link to comment Share on other sites More sharing options...
adamsayash Posted November 25, 2015 Author Share Posted November 25, 2015 Thank you Stephan. Link to comment Share on other sites More sharing options...
adamsayash Posted November 25, 2015 Author Share Posted November 25, 2015 Thank you so much Martinhoura. Link to comment Share on other sites More sharing options...
