Animation loop
godzycabari
Hi guys, quick question, couldn't find any 3d related info on that topic anywhere.
I'm new to animation and i'm trying to animate low poly 3d object with noise modifier...Problem is that i'm animating "phase" slider for the effect i need but when i try to make it loop it reverses animation in order to loop it and it looks weird, do any of you know how to work around that ?
Thank you a lot in advance.!
Hello Arthur...
Did you tried to use the keyframes from the beginnig of animation at the end?
Or you can try rendering only half of the animation and doing the reverse part on the post production...
But tell me a little bit more of your animation so i will se if i'm able to help you... :)
