xoserodriguez Posted December 1, 2015 Share Posted December 1, 2015 I am having problems trying to set up a farm of 2 computers to help with my renders. Both of the computers comunicate without any problems, I could run a Backburner render with my farm. But when I try to run a distribuited render with Vray+3ds max, the 3ds max on the slave computer crash, no matter the size of the file, nor the using maps, textures or whatever. Does anyone know the solution for this issue? I driving me crazyy for days. Regards Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 1, 2015 Share Posted December 1, 2015 What does the VRay Log say on the render nodes? Link to comment Share on other sites More sharing options...
xoserodriguez Posted December 1, 2015 Author Share Posted December 1, 2015 The pop up says: 3ds Max application stop working. The program stop working properly because an issue. Windows will close the program and will notify you a solution. I cant find the vray log file, can you help me location it on windows 7. Thank you Link to comment Share on other sites More sharing options...
Scott Schroeder Posted December 1, 2015 Share Posted December 1, 2015 Does the Vray DR app successfully launch the copy of Max and the crash happens when a job is sent or can the DR spawner not successfuly launch the copy of Max? When using the DR app, you should see a copy of Max running at all times in your windows bar. We've been seeing issues in our office with certain machines not allowing the DR spawner to launch Max. It's a pretty simple fix and it is related to our security policies not allowing Vray to register the menu's, which crashes Max instantly. You can test this out by just trying to luanch Max, it should crash right after loading all of the plug-ins. If you uninstall Vray, max should start perfectly. After you have a new install of Vray, navigate to your ProgramFiles/Max/Scripts/StartUp folder and look for "vrayinstall.ms" and delete this file. This is the file that Vray needs to access on launch, but sometimes if you do not have full admin rights Vray can't delete it after launch like it wants to and crashes Max. It also might help to fully delete all of your Max folders in your User directory for good measure and let max create all new and fresh ones on launch. Link to comment Share on other sites More sharing options...
xoserodriguez Posted December 2, 2015 Author Share Posted December 2, 2015 Thank you, Mi issue is when a job is sent, I can see the 3ds MAx running on my windows bar, but when a job is sent then the 3ds max get crashed. Nevertheless I am going to test your solution. Best Regards Link to comment Share on other sites More sharing options...
xoserodriguez Posted December 2, 2015 Author Share Posted December 2, 2015 I already test the solution and never found a vrayinstall.ms, must be any other issue. Still looking... Link to comment Share on other sites More sharing options...
Scott Schroeder Posted December 2, 2015 Share Posted December 2, 2015 xoserodriguez said: I already test the solution and never found a vrayinstall.ms, must be any other issue. Still looking... If you don't see the file, then everything registered correctly. Try opening up a copy of Max on the machine and checking to make sure that you can choose Vray as the rendering engine, that it is indeed getting a license, and that you can render with Vray. Now, try to open the scene that you are trying to DR on this machine. Does everything load correctly? Are you missing any plug-ins like Forest Pro, MultiScatter, etc? This way you can eliminate Max and Vray from the list and you know that the issue is somewhere in the DR process. Link to comment Share on other sites More sharing options...
xoserodriguez Posted December 2, 2015 Author Share Posted December 2, 2015 Everything checked and ok. I am running Vray 3.0 2015 with 3ds max 2016, could that both versions are incompatible? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted December 2, 2015 Share Posted December 2, 2015 xoserodriguez said: Everything checked and ok. I am running Vray 3.0 2015 with 3ds max 2016, could that both versions are incompatible? There's your issue. You need the 2016 version of Vray to work in Max 2016. Vray doesn't scale up or down. Link to comment Share on other sites More sharing options...
xoserodriguez Posted December 2, 2015 Author Share Posted December 2, 2015 Thx, I will try. Link to comment Share on other sites More sharing options...
xoserodriguez Posted December 4, 2015 Author Share Posted December 4, 2015 Finally that´s was the issue I need to update to Vray 3.20 for 3ds max 2016 and its working. Render downs from 14min to 10min, with 2 computers farm, not bad for small ofice use. Thank you all for your help Link to comment Share on other sites More sharing options...
