edoardopalazzi Posted December 4, 2015 Share Posted December 4, 2015 Hi body, i have a problem with vray for maya, i try to make a label of a beer bottle with a png texture. I put the label in the diffuse color and the W/B image in the opacity map. All seems to be all right, but when i try to render, if the label it's too close at the glass the alpha of the png file is grey and it's not transparency, then if i move a little bit far the lable from the glass, the render is good. I have 2 test render just to show you my problem. Hope someone have a solution. Thanks! Link to comment Share on other sites More sharing options...
John Dollus Posted December 4, 2015 Share Posted December 4, 2015 cool effect. Could be coplanar confusion. try changing your secondary ray bias from 0.0 to .01 Link to comment Share on other sites More sharing options...
edoardopalazzi Posted December 4, 2015 Author Share Posted December 4, 2015 I have already set it at .01 Link to comment Share on other sites More sharing options...
