F Suarez Posted December 9, 2015 Share Posted December 9, 2015 Hi everyone. I’m still using Vray 1.49 (for SkethcUp), and recently I’ve been playing more and more with IES lights, but I’ve come across a problem. Instead of using a generic IES light I tried to use the IES light of a specific lamp, available at the manufacturer’s website (it's under ''Documentation''), but it doesn’t seem to work. http://lighting.cree.com/products/indoor/lamps/mr16-series When alerted to this, their reply was: ''You will need lighting software to view the information. I use Photometric Toolbox and/ or AGI32.'' Maybe VRAY isn't compatible with all IES files? As example, this is the type of IES file that works perfectly on my setup: -------------------------------------------------- ERCO Leuchten GmbH 3399_0 - IES format ERCO 89064 ERCO Double Focus Downlight DL40-QT12-2HA-SI-DOUBLE 1*QT-ax12 100W/12V light output ratio: 0.5912 ident no. for symmetry: 1 D694 TILT=NONE 1 2200 2.2 19 1 1 2 0 0 0 1 1 100 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 0 681.879276637 557.110079287 490.896871945 628.387368307 682.069349408 430.426577604 286.398935592 254.901162159 76.9183773216 18.9393939394 11.0377973281 .488758553275 .00678831323993 0 0 0 0 0 0 END -------------------------------------------------- I'd appreciate all hints and suggestions. Thanks for reading. Link to comment Share on other sites More sharing options...
