Material Glass Problem
luisguimaraes
Hello,
I'm making a simple VrayMtl Material, Diffuse to Black and Refrack to white. It should be transparent, but it's not working.
I enable GI, and set irradiance map and light Cache
The object are 2 simple planes.
Can you help me??
The image have the result with a simple MTL material and without the object.
Thanks in advance for help me
If you are brazilian:
Pensei nisso... eu sempre me confundo quando seleciono o elemento do vidro e as faces aparecem viradas, quando na verdade estão certas. Isso me irrita.
If you are not brazilian:
I thought it could eb that.... I always confuses myself when i select the glass element and the faces shade like it was backwards, but they are correct. It pisses me off.
