adamsayash Posted December 13, 2015 Share Posted December 13, 2015 How to save the rendered image as I see it in the Vray frame buffer when (display colors in RGBs space: is turned off) IMAGE (1). Because Every time I save the image I found it saved as in IMAGE (2) :where RGBs space is turned on! Thanks Link to comment Share on other sites More sharing options...
TomasEsperanza Posted December 13, 2015 Share Posted December 13, 2015 How to save the rendered image as I see it in the Vray frame buffer when (display colors in RGBs space: is turned off) IMAGE (1). Because Every time I save the image I found it saved as in IMAGE (2) :where RGBs space is turned on! Thanks The RGBs button allows you to "view" the 32bit framebuffer linear image as if it were an 8bit image with gamma, but when you save it out you still have the choice, so you have to select the desired gamma and format settings in the save dialogue. For example: .EXR with gamma 1.0 (for linear for post production), or .jpg with gamma 2.2 for straight up image. This explanation may not be as good as is could be, but I hope it helps. Link to comment Share on other sites More sharing options...
