F Suarez Posted December 14, 2015 Share Posted December 14, 2015 Hi everyone. I’m still using Vray 1.49 (for SkethcUp), and recently I’ve been playing more and more with IES lights, but I’ve come across a problem. Instead of using a generic IES light I tried to use the IES light of a specific lamp, available at the manufacturer’s website (it's under ''Documentation''), but it doesn’t seem to work. http://lighting.cree.com/products/indoor/lamps/mr16-series When alerted to this, their reply was: ''You will need lighting software to view the information. I use Photometric Toolbox and/ or AGI32.'' Maybe VRAY isn't compatible with all IES files? As example, this is the type of IES file that works perfectly on my setup: -------------------------------------------------- ERCO Leuchten GmbH 3399_0 - IES format ERCO 89064 ERCO Double Focus Downlight DL40-QT12-2HA-SI-DOUBLE 1*QT-ax12 100W/12V light output ratio: 0.5912 ident no. for symmetry: 1 D694 TILT=NONE 1 2200 2.2 19 1 1 2 0 0 0 1 1 100 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 0 681.879276637 557.110079287 490.896871945 628.387368307 682.069349408 430.426577604 286.398935592 254.901162159 76.9183773216 18.9393939394 11.0377973281 .488758553275 .00678831323993 0 0 0 0 0 0 END -------------------------------------------------- I'd appreciate all hints and suggestions. Thanks for reading. Link to comment Share on other sites More sharing options...
John Dollus Posted December 14, 2015 Share Posted December 14, 2015 I'd wager it works exactly as intended. The lumen output of the Cree lamp file is 539.4 for the 50 watt version so you will likely have to add a multiplier to vray for it to show up in your render. start with a huge multiplier (1000) and then adjust from there if you are only interested in getting a light scallop pattern on the wall. Link to comment Share on other sites More sharing options...
F Suarez Posted December 14, 2015 Author Share Posted December 14, 2015 (edited) Thank you very much for your post, John. You are right, the lumen output is indeed the problem, it’s very low. So much that I completely missed it in my tests, my other lights were a lot stronger. Now only using this one. Can you please suggest the best way to add the multiplier? I tried to change the Power in Vray, but it seems there’s no effect. I'll attach image. I also tried to change the IES file through Notepad, from [_ABSOLUTELUMENS] 539.4 to [_ABSOLUTELUMENS] 539000.4 but there’s no change. Thanks again for your help. Edited December 14, 2015 by fsuarez Link to comment Share on other sites More sharing options...
SkylineArch Posted December 15, 2015 Share Posted December 15, 2015 It looks like your light is in the ceiling, try to move it down some, and/or, check your render settings, make sure you are setup for interior renderings. Link to comment Share on other sites More sharing options...
F Suarez Posted December 15, 2015 Author Share Posted December 15, 2015 Thanks for your post, Mark. I just tried to move the light down a few inches, but no significant change, lumens still very low. Not sure about having everything correctly setup for interior rendering, tho. I learned through tutorials so my knowledge varies from reasonably acceptable to rather incomplete. Where in Vray can I adjust it? Link to comment Share on other sites More sharing options...
SkylineArch Posted December 15, 2015 Share Posted December 15, 2015 On the top of the vray options dialog there should be a presets drop down, you can start from there. Link to comment Share on other sites More sharing options...
John Dollus Posted January 5, 2016 Share Posted January 5, 2016 In the VrayIES options, there's a power option right under the color mode option. Change that to increase it. Link to comment Share on other sites More sharing options...
F Suarez Posted January 7, 2016 Author Share Posted January 7, 2016 Only today getting back to this, I got some results but i’m still kind of stuck. I decreased a LOT the shutter speed, to 1.0, and now the lights are visible, but the image has a huge amount of noise. I’ll attach here the Options Editor settings. Regarding John Dollus suggestion, I tried it, but without success. As you can see in the first image attached, the power is currently at 9500, but even if I change that value to 950 000, there’s no change in brightness. Link to comment Share on other sites More sharing options...
F Suarez Posted January 26, 2016 Author Share Posted January 26, 2016 Any suggestion to decrease all that noise? It's surely caused by the huge exposure time, but without that the lights are too faint. All suggestions are welcome. Thanks in advance. Link to comment Share on other sites More sharing options...
John Dollus Posted January 27, 2016 Share Posted January 27, 2016 fsuarez said: It's surely caused by the huge exposure time, . nope. In your image, it looks like you are putting the IES source behind some geometry (maybe you are trying to have a lens). IES sources should never be placed withing the actual light location unless you make the fixture geometry not affect the light source (not cast shadows etc) IES is generated by testing the light effect AFTER it leaves the fixture. Remember, these are for engineering analysis purposes; not for making pretty pictures. Link to comment Share on other sites More sharing options...
F Suarez Posted March 17, 2016 Author Share Posted March 17, 2016 John Dollus said: In your image, it looks like you are putting the IES source behind some geometry I've been away, but want to thank you for your post. You are totally correct. To make sure the lights are on the ceiling as in reality I usually place them less than 0.5'' from it, and never had a problem, but this IES was different. As soon as I moved it down a bit, the noise vanished. Thank you very much. Link to comment Share on other sites More sharing options...
