jucaro Posted November 22, 2004 Share Posted November 22, 2004 Is anyone here configured backburner server service successfully? I'm wondering what i'm doing wrong. If i use backburner as a standard app, everything works as expected. BUT when I run it as a service, the renders cannot locate the irradiance map and some of the texture maps as well. Anyone have had this problem? Link to comment Share on other sites More sharing options...
Esteban Posted November 22, 2004 Share Posted November 22, 2004 Hello. I had similar problems... with the servers running in service mode not finding the path for the maps..or sometimes rendering to a network drive. I think is something with the paths within DOS tried many things got frustated.. and went back to normal server.. the closest thing to running as a srvc. was making a alias of the program in the startup folder... turn on the render slaves and the server is running.. not much help , just sharing.. if you find a solution please post it.. Esteban esteban@citrica.com Link to comment Share on other sites More sharing options...
abicalho Posted November 22, 2004 Share Posted November 22, 2004 A service runs as a separate user, and usually a very restricted one (usually System). You have to go to Control Panel > Admin Tools > Services and select the Server service, right-click it > Properties and set the username and password of a user who has access to the maps, shares, etc. Hope this helps, Alexander Link to comment Share on other sites More sharing options...
Chris Johnson Posted November 22, 2004 Share Posted November 22, 2004 I am running backburner as a service on my other computer. I configured a year and a half ago, so I don't remember much though. However I do remember that I read the directions in the Max Help file. I followed those exactly and they work fine. Also to check the status of your services: 1. right click on "my computer" 2. select manage It brings up a system information dialog for your computer 3. Open up "Services and Applications" 4. Select Services 5. Drag the window so it's alittle bigger 6. Scroll to backburner in the list. There you will find information on it. Link to comment Share on other sites More sharing options...
MongoMan Posted November 22, 2004 Share Posted November 22, 2004 http://www.discreet.com/support/combustion/faq/answer.php3?prod=combustion&id=1218 Link to comment Share on other sites More sharing options...
MongoMan Posted November 22, 2004 Share Posted November 22, 2004 Im interested in this as well heres one more link that may help you http://www.discreet.com/support/max/faq/answer.php3?prod=dddstudio&id=1359 Link to comment Share on other sites More sharing options...
quizzy Posted December 20, 2004 Share Posted December 20, 2004 I've now installed the backburner servers as services. And changed the user to one that has access to all drives and maps etc. The only thing is, they render, but I dont see max running eventhough I checked the viewport thingy. It shows in the task manager ofcourse. Its not that I dont like it or anything, but I just would like to know what is causing this.... I do have a mixed environment now ie; server as service (on 2 computers) and server normal (on 3 other computers). Just for testing purposes. Link to comment Share on other sites More sharing options...
abicalho Posted December 21, 2004 Share Posted December 21, 2004 Hm... I'm not sure if there's UI when a service is running, because it doesn't run as you, it runs on its own. I think it runs entirely in the background. Alexander Link to comment Share on other sites More sharing options...
jucaro Posted December 22, 2004 Author Share Posted December 22, 2004 I've had backburner running as a service and working smoothly now. I kinda like the 'mode' where there is no display. Question is, If the backburner service runs in the background, does it mean it will be running slowly since it wont be getting that much processor timeslice if windows xp on the stations are configured to prioritize foreground applications? Just wanna know. On another note, Has anyone tried FranticFilm's Deadline Rendering Manager? I requested a demo but I havent had the time to tinker with it after a failed installation. Link to comment Share on other sites More sharing options...
