stayinwonderland Posted December 18, 2015 Share Posted December 18, 2015 Studio/Institution: ArchVizSeattleGenre: Residential ExteriorSoftware: 3ds max, vray, forestWebsite: http://architecturalvisualizationseattle.com/Description: Overall this piece is a level up for me. I spent a SOLID week trying to figure out how to make my grass less uniform and more realistic. Became obsessed with grass every time I saw it in real life But I'd like to know how to move beyond this if anyone has any advice. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 18, 2015 Share Posted December 18, 2015 Glass is all about reflections, if you place object around your scene or in the area that will be reflected by the glass it will make it look more "real". Also if you model each panel separated and instead of using a large polygon, then you can select each individual panel and rotate just a little so they all are not facing exactly in the same direction, this will create color and reflection variance that really help to sell the effect. you could also collapse all glass meshes and apply a small noise modifier to the vertex, this will create planes variations in your glass. just the same effect that you get modifying each panel separate. That image is looking really good BTW. Link to comment Share on other sites More sharing options...
stayinwonderland Posted December 18, 2015 Author Share Posted December 18, 2015 Thanks a lot for the tips. I'll definitely be applying those in future! Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 19, 2015 Share Posted December 19, 2015 ha ha ha I just realized you wrote Grass, and not glass..... man I been drinking too much coffee today. What an idiot ha ha ha If you are using Forrest pro or multi scatter, try to increase the size variations and rotation, defaults are OK but sometimes more variation help in large areas. In Forrest you can activate clusters, they look very real. Also less is more. if you look picture of landscaping there is several empty areas or areas with less dense grass or planting, when you add those areas it really give depth to your landscaping. Other than that color variation and some dodge or darken in Photoshop should do the trick. Link to comment Share on other sites More sharing options...
stayinwonderland Posted December 19, 2015 Author Share Posted December 19, 2015 Ha, funny. Coz the glass tip was useful anyway But man, with foliage, I do all the above but it just doesn't want to play ball. I did the best I could with the speed of computer I had and time given but I still have a ways to go. Link to comment Share on other sites More sharing options...
andrewmunene Posted April 7, 2016 Share Posted April 7, 2016 Awesome job. what's your post production pipeline? there are a number of things you can do after rendering to further push the realism of a render. Link to comment Share on other sites More sharing options...
SkylineArch Posted April 7, 2016 Share Posted April 7, 2016 Try to cut the grass. People with a house that nice usually own a lawn mower. When I see renderings like this, it makes the house look abandoned. I know this is more of an exercise for you, but that's my two cents. Side note, the door handles are too high, they should be around 3' above the floor. That being said, it's still a nice rendering. Link to comment Share on other sites More sharing options...
joshuastephens Posted April 9, 2016 Share Posted April 9, 2016 Without reading some of the other posts, the things that stand out to me are the unrealistic grass, it needs to be cut and is never so uniform. It looks like a carpet as it rolls up the hill where the man is standing. The handles on the door are also too high, they need to be quite a bit lower. The silvery looking connections stand out too much IMO and is deterring from the realism. The glass balusters are also quite larger than life and are very unlikely in this type of home, especially on the roof. The glass on the side of the building facing the man, and on the far left of the porch look great though. The stairway and the layers of roof on the "porch" area look a little boxy and flat. Overall it is a nice image, just pointing out things that my brain is picking out as unusual/non-realistic. Link to comment Share on other sites More sharing options...
