mikekime Posted January 8, 2016 Share Posted January 8, 2016 Hi. I created a VRaySun and I believe it changed things about my scene. I'm noticing I have a blue sky and infinite floor. This does not match my environment as I've unchecked "use map" and there is no physical floor. Where do I edit this? How do I get back to what I had before I ever added the Sun? I've since deleted the sun object but other effects remain. thanks Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 8, 2016 Share Posted January 8, 2016 did you removed VRay sky from your Background environment map? Link to comment Share on other sites More sharing options...
mikekime Posted January 8, 2016 Author Share Posted January 8, 2016 I cleared enviro map under Rendering->Environment. And also "Use Map" is unchecked. I still have a dull blue sky and a grey infinite floor. I think it set this up after I placed a VRaySun into the scene. It asked if I wanted a sky and I said yes. But where does this exist? How? I don't see an object in the world that represents this effect and I also don't see settins in the Render dialog inside the VRAY tab that indicate anything. I don't know how to turn all this stuff off. None of the environment stuff is checked on in the VRAY tab.. I.E GI Environment. thanks Link to comment Share on other sites More sharing options...
mikekime Posted January 8, 2016 Author Share Posted January 8, 2016 I think I figured it out. It is a VRayLight set to Dome that is doing this. I didn't know it had that effect. I want the light effect from it but no change to the background image if possible. Sorry for the confusion. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 8, 2016 Share Posted January 8, 2016 make the light invisible, there is a check box for that. Link to comment Share on other sites More sharing options...
