mikebolton Posted January 16, 2016 Share Posted January 16, 2016 Any ideas how i could create this material? Need the centre of an object to glow but all the edges to be darker! Link to comment Share on other sites More sharing options...
Andres Saarnak Posted January 16, 2016 Share Posted January 16, 2016 Vray light material with VrayEdgesTexture. Link to comment Share on other sites More sharing options...
mikebolton Posted January 17, 2016 Author Share Posted January 17, 2016 Can you blur the edges on edge texture? So the lines aren't so defined? Link to comment Share on other sites More sharing options...
Andres Saarnak Posted January 17, 2016 Share Posted January 17, 2016 I´m sorry, I meant VrayDirt not VrayEdgesTex. In VrayDirt you should check invert normal. Good tutorial on VrayDirt is on http://www.peterguthrie.net/blog/2009/10/vray-dirt-tutorial Link to comment Share on other sites More sharing options...
stefambatros Posted January 17, 2016 Share Posted January 17, 2016 You could also try a composite map with 2 layers : falloff with two shades of blue as 1st layer and on top of that Vray dirt (in multiply mode). Link to comment Share on other sites More sharing options...
CliveG Posted January 18, 2016 Share Posted January 18, 2016 I'm curious, is the image of the desired effect a real photograph? As to me.... it looks like a CG image already and not a particularly good one at that. I hope I'm right here, but I'd be looking to get a more convincing target image and aim for that rather than something that doesn't look that realistic in the first place (to me anyway). In the past I've had good results with actually modelling something like this, using plane lights with falloffs, but admittedly a much simpler shape so I'd probably be starting with similar to the above advise if it's a complex shape like your image. Link to comment Share on other sites More sharing options...
inpow watir Posted January 20, 2016 Share Posted January 20, 2016 http://www.vray.com/vray_for_3ds_max/manual/vrayfastsss2_examples.shtml Link to comment Share on other sites More sharing options...
lenabrel1 Posted January 21, 2016 Share Posted January 21, 2016 hi friends, look at new vray 3 for 3ds max sp1, looks fantastic http://3dtutorials.net/tutorials/3d-studio-max/v-ray-3-0-for-3ds-max-sp1 Link to comment Share on other sites More sharing options...
