Building dedicated workstation for rendering and animation on Rhino and Vray
Hi guys,
Currently trying to spec a dedicated rendering workstation for the architectural office I work in. Predominantly will be used for Rhino, Vray and Photoshop. The main output will generally just be still images, although we will also need to produce animated walkthroughs, etc. These won't be as technically advanced or demanding as a lot of the animation stuff that I'm sure people on this forum spec for, but I'd still like to make sure I have enough power to not struggle with these.
Any help would be much appreciated, never assembled a PC before!!
Case
STYLISH PIANO BLACK ENIGMA CASE + 2 FRONT USB
Processor (CPU)
Intel® Core™i5 Quad Core Processor i5-6500 (3.2GHz) 6MB Cache
Motherboard
ASUS® Z170-E: ATX, LG1151, USB 3.1, SATA 6GBs
Memory (RAM)
32GB HyperX FURY DDR4 2133MHz (4 x 8GB)
Graphics Card
INTEGRATED GRAPHICS ACCELERATOR (GPU)
1st Hard Disk
500GB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 16MB CACHE
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply
CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
Processor Cooling
INTEL STANDARD CPU COOLER
Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Sound Card
ONBOARD 8 CHANNEL (7.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
2 x ONBOARD 10/100/1000 GIGABIT LAN PORTS
USB Options
MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Power Cable
1 x 1 Metre UK Power Cable (Kettle Lead)
Operating System
Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£79)
Office Software
FREE 30 Day Trial of Microsoft® Office® 365
Anti-Virus
BULLGUARD INTERNET SECURITY - FREE 90 DAY TRIAL
Monitor
BENQ GL2250HM LED 21.5" 1920 x 1080, 5MS, HDMI, D-SUB, DVI-D (£98)
Warranty
3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Delivery
STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time
FAST TRACK 5 WORKING DAY DISPATCH (£29)
Quantity
1
Price: £813.00 including VAT and delivery.
So, you'll be running Rhino with the integrated gpu? I don't think it will suffice. I happen to run Rhino myself (it's my main CG software) with a gtx 780 and it's a demanding program.
Also, no ssd in a new system?
The psu is not a good choice at all.
Mediocre monitor and too small for CG jobs.
I'll stop here. I think you should raise the budget a bit in order to get something decent.
+1 What Nikolaos said.
And make sure you get Windows Pro, not the home edition. (Its better for networking stuff and a lot of CAD/3D packages will only install on Pro - may not be the case with Rhino)
Try and get an i7 instead of an i5
GTX 970 GPU with 4GB ram should be fine.
For the PSU you'll need at least a 650 or 750 or higher one
Not to mention the RAM limitations! on Home editions, btw.
+1 here: SSD is a must, Good CPU is a must, Good GPU is a must.
Do you have many other computers in the office that can double up as render nodes? This might effect your choice of CPU/s.
Edited by TomasEsperanza
Ditch the DVD and blu-ray. Who uses optical drives these days anyways? You can push that cost to upgrading other components. Your motherboard should come with a decent sound card option. There is no need to go anything better for a workstation as you use headphones probably 100% of the time.
You'll want to go with an i7 if you plan to render, 650 watt PSU should be fine. Way too many people put in too high of wattage PSU's and waste money there. You might want to look at something other than a stock intel cooler. It probably doesn't have to be water cooling, but stock coolers usually don't work so well on a rendering system.
Only a 500 gig platter hard drive as your main drive? What is this, 1992? Go much higher as these are cheap. You'll want at least a 250 gig solid state as your app drive. You'll never look back once you run solid states for your apps. Use the platter drives for asset and non-essential apps.
You really should check this site out: https://pcpartpicker.com/ I used it to build my recent computer at home. It does a really good job at telling you potential conflicts between your components and your general wattage consumed.
The biggest wastes of budget are choosing an over designed case, "gaming" RAM, "gaming" motherboards, and much higher than you'll ever need PSU's.
This is what I would consider as a minimum in this case: PCPartPicker part list
OS is not included. RAM is easily upgradable to 32gb. 16gb is an absolute minimum these days, but the whole system is very basic in many aspects, but decent, nevertheless.
I didn't choose the 6700 (non-K), because it costs only 20£ less than the 6700K, and you'll be needing the extra boost in rendering (the 6700K is 10-15% faster in rendering).
