simonm Posted February 7, 2016 Share Posted February 7, 2016 Hi all Someting that ive never known how to do (embarassingly) is correctly map a texture to a correct UVW map. For instance, if I have a texture map that is 2000x1345 pixels for instance - if i applied a UVW map, what numbers within the UVW parameters would i need to enter to correctly map this texture so that it doesnt stretch in either height or width if that makes sense. Much appreciated Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 8, 2016 Share Posted February 8, 2016 you could use the bitmap fit button on the uvw map modifier. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 8, 2016 Share Posted February 8, 2016 I cheat. I put the image size in pixels into the render output size boxes and lock the image aspect ratio, then input the new size that I want it to be and it'll scale it proportionally. Then just put those values into the bitmap and reset the render output back to whatever it was before. Link to comment Share on other sites More sharing options...
simonm Posted February 9, 2016 Author Share Posted February 9, 2016 Thanks for the replies guys will gvive it a crack thanks again much appreciated. Link to comment Share on other sites More sharing options...
