mustafisufi Posted February 16, 2016 Share Posted February 16, 2016 hi everyone. Can somebody help me how to do a three-quarter section in 3ds max. from one box i want to remove only 1/4 part of it. is there a way to do it? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 17, 2016 Share Posted February 17, 2016 what are you trying to archive? if you remove some faces or part of a mesh in 3d max you'll the the thin wall and empty interior of the mesh, there are not solids in 3D max. If you want to section some elements you may need to model the inside also. if you understand this, you can use the slice modifier, you can add as many as you need to create the effect. To cover the wholes created, you could use the cap modifier, but depending of your mesh it may not create the effect that you are looking for FYI. Link to comment Share on other sites More sharing options...
miguelcalvo Posted February 17, 2016 Share Posted February 17, 2016 Like this? I used booleans for every piece of this valve, The slice modifier has the limit of slice objects only by a 2D plane. Link to comment Share on other sites More sharing options...
mustafisufi Posted February 17, 2016 Author Share Posted February 17, 2016 thnx for reply. i wanted to do something like this, is there a way i can do it in max ? because if i use slice modifier it remove me one half of the object i want just 1/4 to remove ? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 17, 2016 Share Posted February 17, 2016 Outside of the Vray Clipper object, the easiest way to do this in Max would be to use multiple slice modifiers set to just refine the mesh, and use an edit poly on top of that to delete the geometry. Though if your object is modeled correctly and if it is like your example, you don't need to slice it. Just use an edit poly modifier, so you can turn it off if you want and get your faces back, and just literally delete the section you don't want. If you need to cap the holes, either bridge or cap them in that edit poly modifier. Link to comment Share on other sites More sharing options...
mustafisufi Posted February 17, 2016 Author Share Posted February 17, 2016 thnx for replies Link to comment Share on other sites More sharing options...
mustafisufi Posted February 17, 2016 Author Share Posted February 17, 2016 in fact for example i have a stadium that i want to make render and i want to remove only 1/4 part of the stadium, in order to see inside and outside of stadium in render. i hope u could understand me Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 17, 2016 Share Posted February 17, 2016 the same apply as mentioned by Scott. Also you could have two renderings one with the whole thing and other only with the 1/4 and blend them together in Photoshop. It may be easy to setup the scene. Just an idea. Link to comment Share on other sites More sharing options...
