.psd image
reubenturner
Greetings to all,
On a computer with lots of files Photoshop 14.0 Extended .jpg, all open correctly. However, one of the important files this morning refused to open jumped error: "Photoshop cannot open files in the" Adobe Photoshop JPEG File "format."
Checked the rest of the files with the extension, everything is fine with them in working order. Tell someone else what to do with
If solution on above doesn’t work or your .psd file is severely corrupted, then I would suggest you following ways contained various tips for crashed Photoshop images
https://forums.adobe.com/message/6698481
http://itknowledgeexchange.techtarget.com/itanswers/psd-repair-tools-for-photoshop-cs6/
https://www.openfiletool.com/psdopen.html PSD Open File Tool
• Open "My Computer" from your desktop. Double-click your hard drive.
• Open "Documents and Settings."
• Open the folder labeled with your user name.
• Open "Local Settings" followed by "Temp."
• Scroll down to the files beginning with "Photoshop" ("PS" for older Photoshop CS builds). This will be followed by a series of letters and numbers.
• Double-click each "Photoshop" ("PS") temp file to open them in Photoshop CS. This is the only way to identify which temp file contains the project you wish to recover. Luckily, because when Photoshop shuts properly it deletes its temp files, there should be no more than three or four.
• Select "Save As" from the "File" menu when you find the temp file you want. This will make the file permanent
