Help- To set my camera to exact front View in 3dsmax & vray
ikrarahamad
Under rendering > Exposure Control > activate Physical Camera Exposure and choose an EV number that works. Vray 3.3
Similarly in vray 2. Choose vray Camera > Select a Working (correct Exposure) vray cam in the Scene and all standard cams will render like the standard cam.
In the render setup menu under the Vray tab there is a Cameras section. From the drop down menu under Cameras choose Orthogonal. This will give you an exact Ortho projection using the Vray Physical Camera once you follow Chris's advice on how to set that up. Or just use the Transform Type-In Menu (F12) to 0-out/ 90-out all the rotation values X,Y, and Z.
