ameenharfoush Posted March 3, 2016 Share Posted March 3, 2016 Hey guys, So, I'm rendering a sequence from f700 to f1100 with animation prepass. Once I loaded the IR map it started giving me this error and max crashes. I was able to render from 890 to 1100 but the rest I was getting this error. I tried the scene convert, render on other pc, merge file. When I render the file again without the IR map instead using LC and IR single frame. It renders fine but the problem is that i have an animation and rendering with brute force is not an option now because today is the DUE I'm using vray 3.2.00.2 Any idea? Link to comment Share on other sites More sharing options...
charliepower Posted March 3, 2016 Share Posted March 3, 2016 Try changing the default geometry in settings from static to dynamic. Link to comment Share on other sites More sharing options...
ameenharfoush Posted March 3, 2016 Author Share Posted March 3, 2016 Same error!! Link to comment Share on other sites More sharing options...
charliepower Posted March 3, 2016 Share Posted March 3, 2016 I usually get this error when I have something corrupt in the scene... Try turning everything off in the layers and rendering. If it renders you have a corrupt model. Link to comment Share on other sites More sharing options...
ameenharfoush Posted March 3, 2016 Author Share Posted March 3, 2016 i turned all the layers off and still same error. I think the problem is from the IR map even though it writes that it was successfully loaded but when i change the ir to single frame it renders fine. Link to comment Share on other sites More sharing options...
